I have been interested in building my own machines since I saw the Gingery designed home made machines: lathe, Mill, and shaper. There are others all made from aluminium castings and steel ways that are flat bars. Gingery-style homemade metal lathe builds | Make: But casting seem to be a complication that doubled the complexity of building a machine. And I do not see a significant supply of aluminum, a second complication.
Concrete on the other hand, stone and sand are cheap and plentiful. Also reinforcement components out of steel are also cheap and plentiful. Casting patters are also typically wood. How to make concrete less likely to fail, crack is understood and the information is available. For example Tyler Ley has many videos on how to keep concrete from cracking. Post stressing concrete is one of the best and easy to do for small items. You can find a bench made with fiber filled concrete with a few theaded rod in plastic tubes bent into a shallow "U" shape to keep the concrete in tension. Two inch thick and like 4 or 5 foot long strong enough for a two pound person to stand in the center. Here is a reinforcement video from Tyler: NASA had a contest to 3D print housing which using Mars materials would be the printing of concrete. This is the video made by the second place team:
Note that the stresses are always highest at the surface of the structure so cast iron components of machines are hollow. Concrete machines also should be make hollow. Say a wall thickness of 2 inch and maybe 3 to 4 inch around the active post stressed steel and the cast in place reinforcement steel. To prevent cracks fibers of steel, glass for concrete or besalt would be used. Bamboo has also been used, plant fibers.
