We've all pretty much heard of the alum bath trick to remove drills, taps, and screws of ferrous makeup when broken off in aluminum.
Not an engine part, but decided to share as an FYI.
A lower trigger housing for a firearm I designed and made.
While adding some detent holes for quick take down pins in the already anodized part, a 5/64 drill snapped off! Noooooo!!!
Well, Alum saved the day after 7 hours soak. Also, the alum bath seemingly totally removed the anodizing!!!
Not sure if it is the dye that was removed, or both dye and oxide layer.
The part had a type III mil spec hard coat.
So, use the alum method on raw, unfinished aluminum!!!
