zeeprogrammer
- Mar 14, 2009
- 3,362
- 13
Robert! How are you?
Deanofid said:Hiya Robert! Haven't seen you around for a couple of weeks. (Glad you're here!)
Dean
mklotz said:Comparative enthalpy of combustion figures...
Methanol - 22.7 kJ/g
Ethanol - 29.7 kJ/g
Propanol - 33.6 kJ/g (Isopropyl is 2-propanol)
So *pure* isopropyl has a bit more heat content but the off-the-shelf stuff is diluted with water.
If the denaturing is done by adding just enough methanol to easily-made ethanol to make it poisonous, it's very likely that the mix has more heat content than the diluted isopropyl.
Brian Rupnow said:Back in the day, I used to make a little moonshine. It burned with a clear blue corona---no yellow to the flame at all. I'm not sure what "proof" it was-----bet it woulda ran your train in fine style.---Brian
zeeprogrammer said:Well...I might have a boiler.
Thanks to Pete's suggestion (as well as everyone else's help on the valve etc.)...I got the mountain bike shock pump set up with the adaptor I made last night.
Pumped to about 57 psi or thereabouts. Boiler will (should) operate at about 15 psi.
tmuir said:Hi,
the best stuff I've found for wicks is the fibreglass rope that is used to seal the doors on slow combustion fire places.
zeeprogrammer said:Thanks tmuir. The kit came with cotton wick. As you point out, it burns up as it runs out.
Thanks Pete. A bit more yet to do.
Thanks Bob. I'll be trying the denatured alcohol too.
Hey Dean! Watcha working on?
zeeprogrammer said:Hey Dean! Watcha working on?
zeeprogrammer said:The English language is so great. :big:
