Hello,
I inherited an old badly cared for power feed. I think it came with the mill new (1987 serial n.). Tried the 220 just to see if things went poof....they did. Took front the cover plate(high/low plate) and what a disaster...totally oxidized. I have pics if you have a strong stomach. Took all apart and decided to try and salvage. Speed selector handle was broken at main shaft. Speed selector has broken nipple(at end of engagement rod). Forward/reverse selector fork(internal part-brass) broken Speed selector main shaft not repairable. The rest I have cleaned up and most things are working smoothly ( whole days worth time).
Question: are there any parts available ? can't even find a complete feed box. would sell parts if one of you were doing a rebuild. Frustrating....could be a good old power feed....weights like 75+ lbs.(guessing here) .
Will send more pics if wanted.
Thank You very much !!
Philip
Battle Ground, Wa.
Philip
Battle Ground, Wa.
