Is it possible to braze brass to mild steel or is there a better way.any tricks would be helpful I haven't done any brazing for about 18 yrs and from memory I want that good at it
Silver solder is my favourite, not quite as strong but you need a bit less heat and sticks to almost anything.
The 2 best tricks are clean material to begin with and not to overheat, if it is spitting then it is too hot, (for brazing and silver soldering)
It can be done but not easy. The melting point of brass is just a little over the melting point of brazing rod. As stated silver solder is a good substitute if you don't need a lot of strength.
