- Sep 2, 2011
- 1,381
- 370
the other day I wanted a large cap nut and wanted it in copper, brass or bronze. not having the necessary tap to cut the threads I decided to take a coupler nut and turn the outside down just a bit and then bronze braze the outside of it. I have no problem sticking 2 pieces of steel together with bronze braze - usually just weld it though, however in this case I need a good thick coat of bronze around it. for the life of me I could not get a thick covering of the nut with bronze as the excess would just drip or flow off the nut. it would have been good if I were just trying to do a repair or stick 2 pieces together but not for the idea I had.
is there a trick to doing a thick layer of bronze on something? or is that pretty much just the way it is.
ended up just buying the tap the next day but I think it would be usefull to be able to build up a part with bronze then machine it back down.
