Hello all
I´m Igor and I am new to this forum. First of all I want to apologize if I say something ignorant in this post, I am a beginner in this hobby and do not have much experience. I am designing a boxer engine that I want to build. I took the blueprints from the VW boxer engine and simplified it to make it much easier to build. I have no previous experience in building engines, although I have always been interested in the subject.
I am just beginning to do the CAD design and would highly appreciate your feedback. I tried to scale the dimensions of hte VW engine by 1:6 approximately, although some dimensions are not accurate. The Bore is 16 milimeters and the stroke is 14mm.
I simplified the cylinder heads and the valve system to make it easier to machine
The theoretical compression ratio (volumetric) is approximately 10 to 1 with this geometry. I intend to use spark ignition for this engine.
I intend to cast the engine block out of aluminium using the lost-pla technique (if it works, if not I will go for something else) and the rest of the part will be machined. I have a mini lathe and intend to get a vertical vice for milling operations.
For the camshaft profiles and angles, as well as the ignition diagram, I do not know which values to use and how much of error margin I have.
Do you think this engine could potentially work or are there any major design flaws?
