I need to bore a 3.25" deep hole a bit under 5/8ths dia. in a piece of 12L14.
Unfortunately my longest boring bar will only go to 2.25" (I can only handle 3/8ths bars.)
I'm looking at a couple of bars from LMS and have a couple of questions.
One is a 6 inch (#1779) that uses carbide inserts. It calls for CCMT21.51 inserts and doesn't come with any.
Can I use TCMT21.51 in it?
The other is a 5 inch (#1720) that uses HSS indexable inserts and comes with 3 inserts, but is twice as expensive as the carbide one.
I would just drill the hole but I can't find a bit of the right diameter and the hole needs a square bottom.
Opinions??????
Dean
Opinions??????
Dean
