Hi, first of all Hpy Xmas ...
I aleady read a few articls but i wanted to be sure about it; i want to know what clerances should i leave between a 25mm cast iron bore and a aluminum piston. Also the clerance between the piston rings groove from the rings?
The engine that im talking on is the Lynx NE15, Ive already built on but now I am building another one with my one design but with the same specs.
i have already machiend the bore from cast iron and lapped it with a piece of round wood which i machiened with some clerance. i used fine corse carburandum then finsihed with autosol. i ran the lathe at about 1000 rev which i think it was too high.i got a good finish but didnt acheive that much cross hatch pattern. i also was wondering for a parallel bore but i achieved a 0.02 greater clerance on the upper part of the bore; which case its better that would have been on the lower part of the bore. i think that im am going to lap again the bore to make it parallel or its better that i have a taperd bore gat the top?? After the i will machien the piston accordingly.
