JMI
In the past I used a rotary table to locate the bolt holes in a bolt circle. Have decided to try the Boltcirc program by Marv Klotz. Have a small problem with the output, which probably means my input is bad. Garbage In/Garbage Out.
If I have an equally spaced 6 hole bolt circle with the first hole to be drilled at 12 oclock and I enter the Angular Offset of first hole as 0 (degrees) and the x and y offset of bolt circle center both as 0 degrees I get good numbers but the labeling of the X & Y COORD appear to be reversed.
See below as output in boltcirc.dat:
[FONT="]Boltcircle specification:[/FONT]
[FONT="]Radius of bolt circle = 0.3750[/FONT]
[FONT="]Bolt hole diameter = 0.0960[/FONT]
[FONT="]Spacing between hole edges = 0.2790[/FONT]
[FONT="]Angular offset of first hole = 0.0000 deg[/FONT]
[FONT="]X offset of bolt circle center = 0.0000[/FONT]
[FONT="]Y offset of bolt circle center = 0.0000[/FONT]
[FONT="]HOLE / ANGLE / X-COORD / Y-COORD[/FONT]
[FONT="] 1 / 0.0000 / 0.3750 / 0.0000[/FONT]
[FONT="] 2 / 60.0000 / 0.1875 / 0.3248[/FONT]
[FONT="] 3 / 120.0000 / -0.1875 / 0.3248[/FONT]
[FONT="] 4 / 180.0000 / -0.3750 / -0.0000[/FONT]
[FONT="] 5 / 240.0000 / -0.1875 / -0.3248[/FONT]
[FONT="] 6 / 300.0000 / 0.1875 / -0.3248[/FONT]
I would like the #1 hole to be at 12 oclock. The X is horizontal and the Y is vertical, yes? What is wrong with my input? Does the "Angular Offset" input allow me to select location of the first hole?
This must be something very simple but I don't see it :wall:.
TIA
Jim
TIA
Jim
