Look up the American Big-Boy locos. I am sure they were chain grates, as 2 humans could not keep them fired for long, hauling coal through the mountains of Virginia?
AJ?: Actually "What size of boiler" do you want to feed?
Check out the "rocket stove". It burns very; cleanly. I built one half way just to chek out the claims. On mine, I built the wood holding (fire box) a little too small. Have not gotten past the basic frames partGrew up where our primary heat was a wood stove.
Using similar is somehow not so appealing - - - except I'm trying to re-think the stove.
The idea is to fire wood chips - - - like landscaping ones not the teeny weeny stuff that is sold for 'home' use.
I get the sensors stuff - - - what I'm trying to figure out is how to feed (that is not simple - - -needing to use the under fire air to get good burn) and how to do a clean burn of the gasses produced in the combustion.
I'm a thinking of something like a high temperature material heavy mesh for the grate (to let ash fall through yet not impede the under fire air).
Where I'm striking out is how to force the burn of the gasses produced.
Ideas - - - suggestions?
TIA
I have seen a few rocket stoves on't web... but most only seem to be for heating sheds and workshops - taking a lot of "Human input" with the fuel feed. I understand they are also of the 1 to 10kW power... for heating water, not steam. Planning for "somewhere between 75 and 100 kW. " (Post#20) needs a much larger power feed, and the screw feeder seems to be a favourite to me. I am sure a screw feeder from an agricultural supplier should be the right sort of size, which can be controlled by motor speed.
wood chip screw conveyor - Search (bing.com)
The air supplied by a blower through the fuel at the base of the fire.
Here's an example of a water boiler about 1/4~1/3rd the size required by AJ... The price is a good reason to make your own!
Atmos P25 Incl. Burner And Screw Conveyor 2,0 M | eBay
Comment on coal feeder systems, etc. within this:
Coal Based Fuel Feeding System for Boiler (instrumentationtools.com)
Or this?
Optimizing Process Parameters of Screw Conveyor (Sugar Mill Boiler) Through Failure Mode and Effect Analysis (FMEA) and Taguchi Method | SpringerLink
Any use or interest?
