I have a project I'm working on, and I'm not sure what the best way to perform this operation would be. Hopefully someone can tell me a better way to do it.
I have a long shaft who's end have a 1" long bearing surface which rides inside a bronze bearing. I have welded an extension onto the shaft, and have already turned the weld bead down to within 0.1mm of the bearing surface of the shaft. The question is, what is the best way to exactly match the diameter of the welded area to the shaft's bearing surface without reducing the diameter of the entire bearing surface?
I tried bluing the shaft and slowly moving the tool bit in until it just took the blue off, but at the point it was taking a slight bit of metal with it as well. Maybe I just need to do it even more carefully?
