Swifty
So, it must be made for regular grinder. Do you grind tools using inside of cup wheels. Are there things can not be done with regular bench grinder while you do regularly with grinders with cup wheels? I am now wondering if I should consider getting a grinder with cup wheels. Someone said that you shouldn't grind free hand with cup wheel grinder. If that is the case, it could be a very expensive set up.![]()
I use these wheels on a cutter grinder that I have, it only grinds on the narrow face. I sharpen milling cutters and 3/8" square lathe tools on it. The wheels have a 1 1/4" bore. I don't think that they would last long if they were used for free hand grinding.
Paul.
