Is that any better. Once you have the vid displaying or playing on youtube, just copy the URL displayed at the top in your browser and post into this page, it will automatically convert things for you. Don't try to use the url given in youtube itself.
Anyway, back to your mods.
I just hope my new machine will work as well as yours after I convert it to CNC, but of course, I will be using much smaller cutters.
I do have a larger mill in my shop, and can do much larger jobs on it, but even though I have 14" of throat available, once you get say the RT with a chuck on, things can get very tight for swinging around a largish cutter.
I worked a few things out and found that by swapping to spindle collets and getting rid of the long ER collet holder, I had gained over 2" in workable height, and the cutters were a lot more rigid. If I was starting out now, I wouldn't have bought the ER setup at all and would have gone for the spindle collets straight away as there is very little difference in cost, even having to buy both imperial and metric R8 collets.
If I could make a suggestion, either make or buy a cheap set of flycutters. If you grind the tips of the cutters into a quarter rad you will find you would be able to take off that 10 thou cut and end up with a mirror finish. I take up to 100 thou (2.5mm) off on brass or ali and you can see your face in the surface finish, half that for ferrous. But of course, much smaller cuts on your machine, but I think you will appreciate the difference.
Anyway, keep up the great work, and hopefully I might pick up a few tips for when I start mine.
From experience, the first thing for you to go for is a DRO setup. It really does make machining a lot more enjoyable, you can forget about backlash in your leadscrews as they measure actual table movement, but please, if you can, save your pennies and go for a better system than the scale type. I started with them many years ago and after struggling with them for a fair while, and buying replacement scales, I could have bought a glass DRO set a couple of times over.
Your next mod should be power feed, especially on the X axis, I don't know if I am lucky or unlucky because I had to fit power feeds all round, otherwise I would have had to give up machining because of injury etc, but having them really does make taking a cut more enjoyable, you can concentrate more on keeping the cutting area clean and getting a bit of lube on there without having to worry about an interupted cut, and again, your surface finishes really improve.
