- Dec 12, 2012
- 2,220
- 1,288
Next job was a small face mill.I set the swivel vice at 45o and held a piece of 25dia bar.Milled a recess depth to centerline of bar + tip thickness
I then filed an undercut for the rear edge to slip under.This directs the cutting
forces away from the screw and into the overhang.Drilled and tapped M4
turned the head of an M4 csk hex socket setscrew and fitted.Dismantled and cut bar to 75mm lg.Chucked in the 3 jaw and turned down to 18dia x 35lg
Reversed and mounted in the 18dia collet.Skimmed OD and end and small chamfer to clear cutting point.Its magic cuts better than a bought one
Next will be a 40mm dia x 3 tip
