- Dec 12, 2012
- 2,220
- 1,288
Made and fitted a splashback and shelf to the rear of the lathe.Fitted an additional timber roof purlin and a centre support leg for the bench
Made a new switch mounting brkt and fitted a double power point
Bolted down the lathe.Machined a test piece using the QCTP,it works well
Lathe was about 4 thou out over 6" so i got it within a 1/4 thou.Like those capstan leveling nuts. Also set the Pratt Burnard chuck but could only get it to 2 thou. I think there needs to be more play between the mounting spigot and recess for it to move more.Any comments welcome as its a first for me
I was going to make a draw bar for my homemade MT3 test bar but realised the Myford has only a MT2 in the headstock so i held between collet and tailstock centre.TS is about 2/3 thou low but easily got it to 1 thou front to back
Now waiting for the thrust bearings to arrive from China so i can finish off the
leadscrew.Then i may try some screwcutting .W
ith low speed and high torque
thru the backgears should be much easier than the C4
