- Dec 12, 2012
- 2,220
- 1,288
Well just a couple hours.Finished the tailstock and tweeked a few things as I think of them or as they surface.
Found the ideal position and bolted the lathe and the switch down.I then checked the h,stock and tailstock heights
I also set the tailstock alignment front to back.Turned a couple of diameters 13 thou taper over 200mm so adjusted
the bed twist using my patented riser feet. The first ones I made I drilled capstan holes for adjusting but on this pair
I only knurled them.For anyone who makes them they are far superior with the capstan holes.Also cut off about 40mm
from the rubber mat it does not as yet curl naturally but it does seem ok so far
