Not siamese anymore but still twins. A very bashed version from Dave Goodfellow's plans. The flywheels where made last April along with most of the engine, was able to finnish it over the holidays. The cylinders are 1" aluminum bar, 1.75 long with brass lining.
The base is 1/4 plate made to look like marble.
The cylinders are textured to look cast.
The valve knob is from 1/2 steel bar.
The valve guides are also lined with brass.
The crank weights are attatched with grub screws so I can change the crank from 90 to 180 degrees. It was fun to build as my second engine.
Kurt
Kurt
