This is the connecting rod model that I made.
I am not sure if I will keep the original hinged rod end, or use a more traditional split cap with two bolts.
The original rod I think had the hinge pin on one side, which I am not fond of.
The idea behind the hinge pin, according to the old catalogs, was so that a user (farmer) could easily and accurately adjust the big end bearing clearance using simple tools, and without requiring any shim stock.
I will definitely make up drawings with a hinged rod cap, but I may use just two bolts, with shim stock on my rod.
0.001" shim stock is readily available these days, and the two-bolt rod cap is a much better design I think.
I checked, and the rod clears the side of the cylinder when the engine is rotated.
The big end of the rod outside diameter also fits down the bore, otherwise it would not be possible to install it, since the hole in the bottom of the crankcase is too small for it to pass through.
