Thanks Ted, Minh Thanh,
That is a very different cam shape. There is a 1/2" wheel that rides on the came and , I think, helps to smooth out the motion. It does drop off suddenly, but the indexer needs an abrupt motion to turn it. So the cam drops off, the spring pulls the lifter down, the indexer catches on the flat spring on the right side, and turns 90 degrees. Straight wire spring on the left stops it at 90
Some pictures, although the cam is behind the flywheel and governor, and a little hard to get a clear look
![IMG_1517.JPG IMG_1517.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/74/74136-99748e2c57df7816f8ece45cd147906c.jpg)
the roller just as it comes on top of the cam,
![IMG_1518.JPG IMG_1518.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/74/74137-c2a800fe42efb6a4172129480f5d4b21.jpg)
as it is about to drop off the cam
![IMG_1519.JPG IMG_1519.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/74/74138-b5e6da9a268274e530080b7bc5be3aa3.jpg)
A bit dark, but the same position from the other side
![IMG_1521.JPG IMG_1521.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/74/74139-cfb5d4887dec8dbbad6e3e877d540251.jpg)
Maybe this one is better
![IMG_1520.JPG IMG_1520.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/74/74140-be354608c1d4827c099c6d467b306df4.jpg)
with the cam lobe and lifter all the way down, almost no contact with the cam.
The instructions say to turn the cam so the exhaust valve is closed 3 degrees after Top Dead Center (TDC) .
I hope that explains well enough, it is an interesting mechanism, and I think it is smoother than the cam would make you think.
I had a slow motion video, but when I transferred it, it came out as a still.
Thanks for looking,
Doug
