- Jan 4, 2011
- 1,435
- 401
Great work. At least you have proven that it can run.
Propcock the water is for cooling. There is a passage from the hopper to surround the cylinder. The Gingery uses this method as well.Fantastic you are a true owner of a Unicorn as far as I have read, like the guy that routinely actually uses his Quorn to sharpen an end mill.
Congratulations ! what is all the liquid in the center? I think as an outside observer
the CDI ignition helps as mentioned by Grim in another Atkinson post and a large flywheel.
The proof is in the running, again congratulations.
Segments??I bought the segments, it doesn't have too much compression I threaded the valve stems easier to find the right spring flexibility the ignition point is precise
They??Outstanding! Congratulations!
They DO run!
There’s a book by Vincent Gingery step by step building an Atkinson engineWhich plans are you building from?
I have plans and casting kit that I sell....Hi Dave, are you selling paper plans? (I.E. Not CAD)?
Ta,
