Bentwings
For our small 10” lathe I hone the edges of carbide inserts sharp with a small radius hone on the leadin point this usually gives a pretty good finish however a sharp high speed steel does just about as well . Under microscope carbide is slightly porous or rough. It is a sintered powder so sharp edges break down under heavy cuts . The chip breakers are there to allow heavier cuts with the chip being s chip rather than a string. I also use some tempered steel shims for lack of a word that are ground and positioned as chip breakers as I don’t like stringy stuff flying around. It takes a little monkeying around to get these to work but once it’s working fine cuts are much easier. I save most carbide for the heavier cuts. Our 10” has a 3 phase motor that’s very powerful so even tough steel like 4140 cuts easily. I suppose one day a gear is going to strip or the lead screw will fail . We have given thought to converting to ball screws but I’m more interested in making a reverse for the lead screw. It a grizzly 602 spin off but has a totally different gear train . Leave it to grizzly yo come up with this system. So far I have not seen another lathe or eve one of grizzly lathes that I could use the gear trains from without a lot of work . If some one has a solution I sure would like to know.Different cutting tools as much as anything else have their place, I was taught in a formal apprenticeship how to sharpen HSS and I still do this on custom tools but given the choice I go carbide inserts every time.
My lathe is an EMCO 5, I am the only owner from new and it is nicely setup, recently I had a job where PCD inserts were recommended, so I bought one off insert at £30 (approx $42), this insert has taken the lathe into areas of accuracy and capability that I never thought possible, this insert cuts so well that it has for all intents and purposes removed spring back, I am able to wind on 2 micron cuts and see the tiny amount of material being removed - quite incredible.
Thanks
Byron
