SignalFailure
- Jan 1, 2008
- 366
- 3
I took the essentials for this from a 1963 Popular Mechanics engine. This is the first full assembly (minus flywheel) but I'm not sure if it'll run yet - I plan to run this on air only which means it has to operate at <10psi to suit my aquarium pump!
The bore is 12.5mm and it's made from mild steel, cast iron (cylinder block) and brass. It's straighforward (if blocky) machining although the crank and eccentric strap are file work (well I bored the 'ole for the eccentric then filed it up to shape).
For metric builders, plans are just about done too, I'll upload them shortly (but only if it runs!!).
