Hi Doug, My wife is in the chassis shop getting a new rear ball joint fitted now. Life will get better when the broken part is replaced.
Meanwhile, I checked (using the ellipse curvature calculation) the largest radius for your Top-Drum end plate.
It came out at ~1.6" radius.
Then checking ASME - which struggles with small parts (Model boilers) - it simply says everything UNDER 2.2" rad shall be at least 0.040" thick.
BUT then there is a further requirement for the Stress Concentration Factor to have 3.3 times the thickness when material is pierced - as for the bushes for the water gauge, etc. Which means it shall be 0.123" thick ... (1/8")! A bit thicker than perhaps we expected?
Can you spin that thick?
Hope this news isn't a problem?
