Hi Rich
I don't use TCT - so below is more of a collection of thoughts than a true answer...
All the TCT tips I've seen for threading looks like the bits
here on Chronos's site (scroll down a bit) - they have well-defined threading tips, and come as either left or right handed for all faces, and in 55 or 60 degrees for the tip.
The angles on the grey tips you show are definitely far smaller than 55 degrees that would be used for Whitworth thread form and looks to be hand-ground. On the other hand, the angles appear to be larger than the normal 20 degrees that would be used for ACME threads...
I'm basing this on the photo; an equilateral triangle (as is the overall shape of all of the tips you show) has angles of 60 degrees at all corners. With the cut-outs on the tips at just below half the full tip angle - i.e. leaving more than 30 degrees carbide - and less than 55 degrees, I don't know of any threading standard suited to that.
The gold tip you show held in your fingers with the raised profile - well, it's difficult to judge its true cutting angle, but it appears more for general use than thread cutting. From the profile shown, it would not cut at a true 60 degrees, and anyway, it would be pretty useless for threading close to a corner with a flange next to it - as is needed so often.
As to measuring the angle for threading tips (and I use these to grind up my own HSS tips) - you need a
thread angle/fishtail/centering gauge. I just grind up my own HSS bits and use the appropriate gauge (55/60 degree) to check the angle for the toolbit - as well as setting the tool up in the lathe.
<Off topic>
And lastly, I'll openly admit that, while I've cut quite a couple of internal and external threads of Metric, Whitworth and ACME forms, I don't think any of them would stand up to "true" quality control tests... - I only needed them to be close enough to work; which they did and still do. IMHO there's too much of a theoretical boo-hah raised by people (most of whom never show their own examples), when it comes to threading on the lathe - which scares off a lot of very capable folk from trying it in the first place. It's not difficult at all, and entirely acceptable results are possible for anyone that's willing to put some effort in to try.
</Off topic>
Kind regards, Arnold
