jj-smith
- Oct 13, 2014
- 63
- 8
Hi Folks,
It's been a while since I've been at it with machines and building things.
I recently made the decision to shift my hobbies to one main one and that has become engine building, along with other small stuff that I can do in the house with the mini lathe, mill and some other shop machinery and tools, some of which I've had for years, and others I've just gotten or rebuilt.
I always wanted to build an engine like Poppin, as I saw my first one at a steam show in around the early or mid eighties.
Life can be busy and fly by in a hurry, and the next thing you know is that you've become older and never did some of the things you always wanted to do.
So..., Here we go.
I started by getting my "shop" ready and sacrificed a small bedroom for now until I can build a room that's more suited to this kind of work.
I started with the cylinder as I read the original author's build log and figured if he thought that was a good place to start, who am I to argue? So did the same thing.
Pictures will show up, but I am not convinced that I know all about "how to do that here".
The first cylinder (picture) is now a memento and example of my eager but lacking skills, so another was carved out and also was not quite right but will work (I think).
Personal touches are allowed and so I plugged on and made it seem like I know what I'm doing :wall:
The fins on the cylinder showing are not as in the plans because I do not have a thin enough parting tool, and the tool I bought to replace the fat one ended up being the same thickness as the old one.
Fine.., use what you have and make it work.
Cooling is not an issue from what I can tell so I will experiment.
Next comes the standard for the engine and after laying it out I then drilled the necessary holes and removed a broken drill end and the bulk of the material to be machined out.
I thought it was going to be a quick build but for some reason the brain can't seem to access the knowledge I once had! Procedures can be a pain when you know little.
After some time, and breaking that one drill off in the hole for the crank bearing cap, I managed to extract (I machined around it) the broken end of it from the standard and merrily carried on like the proverbial bull in the china shop, but am happy as a lark! (And more careful.)
A few of the holes are not quite as they should be, but then the government isn't what they say they are either, and if they can get away with it, most likely I can too
After a few weeks I progressed enough with both the standard and the cylinder to carry on with courage and made the cylinder head, and it fits!
The piston is next while at the same time I will either turn up two flywheels or work on the crank shaft and its related parts.
I needed to see the few parts (roughed out and not finished) together, so I fitted things so it looks more like what it is supposed to when finished, and I must say I am happy to report that it actually doesn't look as bad as I thought it would be, and have hope that I will not be thrown to the dogs by some of you, who comparatively speaking, are the Kings of machining excellence.
No magazine will ever do an article on my exquisite layman's masterpieces!
This is what I have done so far, and with a bit of luck and less snow up here, I could probably finish this by spring, as I am seldom home long enough to lay hands on my machines for too long.
Anyway, the last thing I got to do was mock up the pieces to see what I have wrought, and I am unashamedly letting you see itwoohoo1
Thanks for watching, J.
So..., Here we go.
