A quick question Edward. It looks like it fires once when the points open twice. Is the engine missing every other firing stroke or is it a sound / optical illusion of the video. It's almost like it's starved of fuel.
Tony
Tony
Tony
I was in contact with the guy who made the first engine. He has his valve timing set to TDC and BDC but the main change he made is to increase the compression ratio. If you go to his Youtube channel you will see the conversation. He said it took a long time to get it running that good and he thinks it's even better now.
I have followed and applied the drawings I've received and scaled them to 1/4 scale in inches vs. metric, however I observe that the 3D model has the piston ending up, seemingly quite a distance from the top of the cylinder at the top of the stroke. I know that you have a nicely operating engine (Congratulations!) Could you advise what the relationship is between the top of the cylinder to the top of the piston is a TDC on your engine? Obviously I need to correct my 3D model, just would like to get an idea of by how much.
