JQ, curious to know if you measured the 'Ring Gap' at the 'Bore' diameter, if so what was it? As mentioned new rings were in the works, thought I'd share photos 1st is the Fixture - it has a .041" pin to establish the gap.
2nd is the HT Fixture simple Cast Iron Nipple two caps, the wood piece is to consume the oxygen, works splendidly-all that remains is a piece of charcoal.
3rd is the HT Fixture in the oven at 1400 F according to the analog temp meter.
All now cooling off in the oven - remove tomorrow when I finish the Pump Piston.
Regarding the use of some sort of gas, if anyone is interested I can provide the dimension for placing the 'oiler' hole such that it would be between the rings when the piston is at the bottom of the stroke (being that I redrew all the parts in Solidworks, it is not very hard to do a measurement), my thought is to make it a #4-40 at most, therefore able to be plugged with a set screw. Believe an oiler with a very small thru hole to be sufficient, anyone have thoughts on that?
Ken:
Cylinder bore is 0.7490 in.
I made rings at 0.062 thick, inner diameter was as close as practically possible to 0.7490 - 0.80 in.
ring gap measured in bore as little as possible, just enough space for me to get the ring in the bore, I thin in practical measurable space of less than 0.004 in with a feeler gauge in a small bore is hard to get real accurate.
I use a very thin slit saw to split the rings.
I made the rings as the usual Trimble process with a lower OVEN temp 1100 F there are many discussions here and some other forums regarding the issues of softer rings created at 1400 F, not sure about this but i have always done mine at 1100.
Outside ring diameter was 0.010 in over desired finished diameter, then placed inside cylinder to adjust end gap, then machined in a custom made arbor for final diameter turning.
Engine ran OK for some time however not enough to call it a RUNNER, so I'M making new pistons and rings.
Will re-hone cylinder with one of those hones that look like bottle brushes, which are great for softening CROSS HOLES since they tend to round the sharp edges in this case the spark plug and ports.
Will make the pistons from Al 4032 (High Silica Aluminium), will use the same ring thickness but will make the piston grooves for rings LESS deep, I usually leave about 0.0010 - 0.0020 in smaller piston diameter than ring inner diameter, this allows easier insertion of pistons etc. This time I will go as close to ring inner diameter as practical.
