Perhaps someone with more experience than myself can help me out. My Odds and Ends hit and miss engine has a strange problem which I can not get to the bottom of. I am running a grey cast iron cylinder and an aluminum piston. I couldn't get the metal rings to seal on the original cast iron piston, so I made a new piston of aluminum and put a viton o-ring on it. The engine immediately started and ran. However---it only runs for 5 to 10 minutes and then seems to be labouring, and quits. However, if I immediately turn the flywheel by hand, it seems to be turning freely, not seizing. If I choke it a bit and spin it with my electric drill, it starts easily again. I have tried both my home made carburetor as per Philip Duclos' plans, and a purchased Traxxas 4033 carburetor---same thing happens. I have tried a different coil---same thing happens. I have tried it in both hit and miss mode and with the governors tied down, and it still does the same thing. I am going to give it a try with a different spark plug and see what happens. My first thoughts were that the aluminum piston would expand at a greater rate than the cast iron bore and perhaps start to seize the piston in the bore, but if that were so, then surely I would feel it when I turn the flywheels by hand immediately after the engine quits. I have tried to pull the sparkplug to diagnose the problem, but I really can't tell from doing that.--The fact that I need to choke it a bit to restart it even when its hot seems to indicate that it is running out of gas.--But--I see no air bubbles in my clear fuel line. I may resort to putting the cast iron piston back into the engine with a Viton ring on it and see if that helps. I really have ran out of ideas here.---Brian
