Brian Lawrence
I plan on just either using a 30° or a 45° angle I think using just a one line seat will just work fine. it works on my vintage Harleys. Try and also get a good strong spring as well.
Brian
Brian
I am poking fun at my ocd every time when I look at it. I did have plans for patterns but after 20 fixture changes I gave up!Hi RLO1. Just wondering what is with the colour scheme on your machine base?? Is that how it came or do you just like colourful machines
Sorry about that the file was too large to upload. I am attempting to correct it.Hi Rio.
I got the "play bar" - but no link to a file to play...
I know that "watching paint dry" can be a relaxing way to do nothing, but watching a "play-bar" play nothing is less exciting. Please can you re-load the file link?
Cheers!
I too have had good success with Brasso as a polish on valve seats. It made a significant difference on both aluminium and steel seats with stainless valves for me ... more than I'd expected. So much so that if I can turn the valve guide and seat in the same setup, a polish with Brasso has provided a seal right away - no other lapping required. (There, I've now jinxed it!).I would also at the very end use Brasso to polish the seats
Seat width varied from a nice polished narrow ring to about 0.030 wide. It all depended on how square I installed the seat. Any variation was removed with the lapping.Can I ask how wide of a seat did you get ? I’ve just been through this process and yer what a pain I found it
This test was just for valve seats. I am going to clock and locktite the cylinder heads to the cylinders during final assembly.Rlo,
How was your pressure test run? Did you pressurize and then with a shut-off valve watch the cylinder leakdown time on a pressure meter? If so, what kind of leakdown times did you see? Also, did this test include the washers selected to correct the head orientations with respect to the block? - Terry
Can you show your parts?Anyone have suggestions on how to "Brad" the pins holding the crankshaft together?? Should I drive them in with Loctite? Do I need to peen them?
