Hi All,
OK so after some proding by a few of you, I decided I would start my own build thread on a Wallaby 2 cylinder in line twin as designed by Westbury. I am starting with the same castings that Metalmad is using on his great build thread, and to be honest, I wanted to not post this build until Pete was finished...But I think he's close enough now. Nice Build if you haven't looked !
I would like this engine to be "marine" like so I will be building it along the lines of a small ship's engine.
I would like to build it along according to the plans and won't be modifying it much beyond piping perhaps.
I've taken a couple of initial cuts on the main block and will be doing some other work on it perhaps this weekend.
I do need to point out that my family and SB overhaul are the number one priorities and I am currently balancing that against my finances and my job which is going NUTS right now....and I suspect that won't change for a few months.
I will be building this engine as time permits, and from the perspective of cash flow with as much of my own infrastructure as possible.....I may make some gear cutters for instance .....
So I ask that your patient .....this will take a while.
Thanks!
Thanks!
