Hi
I can take no credit at all for this displacement lubricator, its one of John Bogstandards designs. He has been of great help during the course of making it. Many thanks John :bow: :bow: :bow:
A piece of 3/8 dia round brass in the lathe. Drilled to a depth of 15/16. I have a set of tapping size drills that I have ground to a flat which enables me to flat bottom holes. Not altogether nec on this job but will slightly increase the capacity.
Then tap for about a 1/4 inch. Here I am using the ground off tap to get a full thread for all of the 1/4 inch tapped.
Move to the mill and cross drill 3/32.
A piece of 3/32 copper pipe in the mill. Touch with a centre drill.
Then drill 0.7mm through one side only. Don't drill right through.
The chamber.
The cross tube. I didn't notice it rolled over the dimension. It can be seen on a later photo.
Drill 3/32 a piece of 3/16 round brass. Cuntersink the end with a centre drill. This will accept the pipe nipple. Thread the end for 3/16 (not shown) then part off to 1/2 inch. Make 2 of these.
Move to the mill and with a 3/8 cutter ( the same size as the chamber) round the ends.
The 2 parts.
Push the copper tube through the chamber with the hole uppermost. Push the 2 brass connectors onto the copper tube.
The filler bung is made from a piece of 3/8 stainless steel round bar.
Knurl
Turn down and thread 5/16 then cut the groove for the 'O' ring.
Use a round profile tool then part off.
The finished part.
Fitted in the chamber.
Its in the pickle now. Hopefully I'll get time tomorrow to silver solder it all together.
Rich
