fcheslop
Hi all it has been a long time since I posted any build/tooling threads , I recently had a small machining job that required 60 pins 0.107 dia for a 160 year old automata at 3 inches long with a 3 degree taper on one end
Im not keen on doing this type of work mainly due to lazyightiss and had though just use the standard travelling steady but what a pain it became
So it was time to make a new steady along the lines of the box tool and one I had seen on Myfordboys site
Its simply two bits of alloy tenoned together with an M6 bolt to stop it coming apart. One bit would have been better but its made from what I had
I hope the pics explain what Im trying to describe and that it may be useful to others who may have not seen this type of steady.
The plus and a great one is set up time and that you can use youre dials to bring the first 1/2 inch to size .
It has been well worth the little time and effort it took to make it.
Here is a wee video of poor quality to show it working.Pleas turn youre sound down as it sound very noisy for some reason.The lathe was running at 2700 rpm
https://youtu.be/lT8nKHqRaFE
cheers
cheers
