Hi
When I built my small boiler I had to stop and build various jigs to hold the boiler tube without damaging it. Armed with that experience I decided to make the holdig jigs first for this project so that is what I have just spent the afternoon doing.
Firstly I cut a piece of 18mm MDF then in the mill machined the edges square.
Can be nasty stuff MDF so I had the vacuum cleaner on all the time while maching it.
Cut a hole in it with my biggest hole saw.
Mounted it on the face plate from behind with large self tapping screws with some 6mm MDF spacers
Turned out the hole until the boiler tube just fits in
Then cut in half and screw and glue to another piece of machined square 18mm MDF
The addition of a bar will allow me to hold the tube in the jig with some plastic cable ties
A steel mandrel with a 10mm shaft and tapped 6mm
A piece of 22mm soft wood is marked out and then cut roughly to shape using the band saw vise
Drilled through the centre 10mm and mounted on the mandrel and turned to size. I have marked the mandrel with a No. 1 so that I always put it in the chuck lined up with No. 1 jaw
Turned to be a good fit internally in the boiler tube
A piece of soft wood screwed onto the face plate
Another piece of 22mm soft wood cut roughly to size
Then screwed to the face plate and turned to be a good tight fit internally in the boiler tube and marked so that I can refit it if nec.
Mounted in the lathe. I can push the tailstock end into the boiler tube as far as nec depending on the job in hand
Heres a shot of the copper I have collected over the last year or so to make the boiler
Rich
