Hi, looks like a very well made engine and I'm sure you will get it running with a little
experimentation. I also had problems getting mine going but finally ended up where it
will run until the fuel runs out.
Here are a few additional ideas which may help you.
I found the cam timing needed to be quite precise, 5 degrees either side of the sweet
spot and the engine would not run. Start at the recommneded timing and then move
5 deg at a time until you find the best spot.
My engine takes a couple of minutes to warm up before it will run. Until then, the hot
air drawn in on the down stroke is cooled too much by the cylinder and head before
the valve closes. I used cast iron for the piston and cylinder and steel for the head,
wonder if your aluminium construction is conducting even more heat away.
The cooling of the hot air in the cylinder once the valve closes will result in the
cylinder pressure being less than atmospheric. This will remain lower for most of the
piston travel towards TDC and consequently the valve will remain tight against the
cylinder head. Close to TDC the pressure will equalize and the final travel of the
piston will cause the pressure to be above atmospheric and the valve to 'pop' away
from the head. The lower the initial temperature of the trapped air in the cylinder the
earlier the valve will pop away from the head on the up stroke. You noted that air
wheezed from the valve on the upstroke when you retarded the timing. It may well
be that the timing was OK but the air trapped in the cylinder was not initially hot
enough to keep the valve closed during the up stroke.
I eventually settled on a 0.004" valve blade cut from a feeler gauge. I found a 0.002"
valve warped very quickly. An 0.003" valve warped in use but returned to flat when
cooled. Although a 0.006" valve worked fine for a while it eventually fractured. Even
now the valve is not perfectly flat but the low pressure in the cylinder is enough for
the blade to flex and seal tight.
I use ethanol for the fuel with a Zippo wick. The wick is teased open into a large
head to produce a large, wide flame. The top of the flame reaches just past the top
of the valve so that on the downstroke, the tip of the flame is drawn in over the top
of the valve and into the cylinder.
I'm sure you are very close. Keep at it and you will get there. I will keep watching
this post for the good news.
Gordon.
