skyline1
- Aug 6, 2012
- 446
- 153
Hi Pat
Until I started building this one I had only used a spot welder very occasionally myself and it was many years ago so I was on a learning curve myself.
This is only designed for thin sheet the maximum I have used it on is 0.5mm (each piece) which is around 20 thou' but I think it would be able to do a little more say around 1.6mm overall (63 thou') It would probably struggle at much more than that.
You don't need to bring the jaws together simply lift the top jaw against the spring and slide the components in the gap. You then just gently let it drop against the bottom one and you're ready to go, use gloves though as it may be quite hot. Check the components are lined up as you want and readjust if needed. Then as the song goes "push the button" .
You could use a spring loaded pedal if you wish, this is simply how I did it. Experimentation is the name of the game with this sort of thing. A foot switch to "fire" the welder would be a good idea though so you could use both hands on the job. You could wire it across the weld pushbutton on the controller and put a socket in the back. A momentary action guitar footswitch would be ideal and they come with a suitable plug fitted (1/4" Jack). Very good idea to turn the welder off unless you are actually welding with it lest you accidentally step on the pedal.
Yes you could make the electrodes shorter for things like tubes as you describe. I think the best way to do it would be to make one longer than the other thus bringing one of the weld arms closer to the circumference of the tube and enabling it to fit inside easier. Have a look on Ebay for spot welder arms for inspiration on this, prices are pretty scary though that's why I had a bash at building one.
Regards Mark
Regards Mark
