arnoldb
- Apr 8, 2009
- 1,792
- 12
Thanks Bill. Its become second-nature for me to have a couple of different grade sheets of emery lying about on a flat surface; as I finish machining each piece, I nearly subconsciously deburr it with a fine file and give it a rub-down on the emery. It helps that I'm getting better machined finishes; less elbow grease :big:
Mel, thanks. I don't know and can't measure the RPM. At a guess that was about 2000 to 3000 RPM at 40 psi - It still wants to go but I'm scared it will break apart as the crank pin is just 1.5mm (just under 1/16") thick and this particular engine design is very out of balance.
Baie Dankie Wagner ;D - Believe me, your 2 hours are more golden than mine; enjoy the missus and the kids - the hobby is a side-line. And once the young ones are bigger, you'll get to spend quality time with them in the shop; better start searching for safety glasses for kids - might be hard to come by in RSA ;D
Regards, Arnold
Regards, Arnold
