Had a hankering to build a twin and after recently building an ML Midge thought it would be a good basis to go down this line of thought.
There is a horizontally opposed Midge and it is called the Dragonfly, but I could find little about it on the Web. So I thought why not build a Vee. Some sketches and calculations showed a 90 degree Vee would have serious pumping losses compared to a single in fact 50% loss for same capacity, but a 60 degree Vee only loses 25% efficiency.
Looked at a couple of other single cylinder engines and settled on the Midge as the underpinnings for stroke / bore etc.
I have carved the crankcase so far - invested about 6 hours with a pencil and paper and another 15 or so in making it. Made a couple of errors so it is going to be a little bit different to my original design, but it should still run the same. The main error was boring the 2nd cylinder hole in line with the first, instead of staggered the width of the conrod. Now this has a plus in that the engine will look neater and a bit lighter, but it has committed me to a fork and knife conrod. I am beefing up the crankpin from 3.2 to 4 mm, but I figure this may not be necessary as the load from double the capacity is spread over 2 pulses not one big hit.
Other specs are as per Midge 10mm bore, 10.16mm stroke, however it will have a ball bearing either end of a longer crankshaft, the crankpin will be longer to take both throws of the conrods, the engine will have a small bolt on plenum chamber above the Vee for a single venturi to feed into and the gases then spread internally to the port. You can see this division in the centre of the flat between the cylinders and the screw holes to bolt the chamber to.
It certainly should run I think, and I can't wait to hear the double pulse per revolution to see what it sounds like.
I will have to learn how to use CAD as I think this engine would make a good little project for those that want something a bit different.
I think I will call it the Butterfly, on another Forum a couple of other names have been suggested, but I think Butterfly sounds pretty good to go with Midge and Dragonfly.
Here's a couple of photos of work so far.
