Dear petertha, I’ve already known the cylinder volume calculation formulas since childhood, which you shared on the link. I’ve reviewed my engine and I saw that I could convert it sandwich system between cylinder and head with squish band and circular combustion dome added, as you mentioned before, thus I could adjust also the CR.
In your previous mail you shared a picture which showed some kinds of engines CR. I’m curious of that what the CR should approximately be for 21mm bore 18mm stroke engine. If I know this ratio I can machined nearly. Then I can adjust more or less by just changing the shims.
If you have any further idea about ratio I will be pleased to hear it.
