Kevork BOYACIYAN
Hi everyone;
I'm Kevork a new member on HMEM, 44 years old and live in Istanbul. Actually I found this forum at 2013 while researching for carburetor. I have several drawings about 2 stroke engine which I began since 14 years old. My father is a lathe machine master so I learned many things from him. I start to work in a factory when I was 19 and became a CNC lathe machine programmer and operator in short time. Also I started to draw technical drawings of our products. I graduated from universty at same time. My factory was always develope so I started to useing erosion machine, CNC milling machine and learn 3D drawing and programming in time.
My father had a Peugeot 404 and he had a repair book "Manuel Pratique De Technique Automobile Peugeot 404 Essence". I don't know french but there was lots of dimensions about engine in this book. I decided to use 1:4 scale of this 1.618cm3 engine, with convert it to two stroke one cylinder engine. Briefly dimensions have been determined of my 6.23cm3 engine with 21mm bore and 18mm stroke.
As I mentioned above I started to my drawings with pencil and paper by hand, years later I digitialized them with AutoCAD and I complete with all components with Solidworks. Everytime when I saw a new machine, like erosion or CNC, or learn new technics, I drew all parts from the beginnig.
I complete my engine almost and I had a lots of photos and videos chronologically of the construction phase and I want to share with you.
I'm not tested my engine yet I will hope to run it while I sharing photos and videos .
I hope you enjoy it.
