- Jul 16, 2007
- 3,072
- 1,212
Here is yesterday and today's progress. I finished up the rods, making the bushings and crank pins or wrist pins if you will. Early this afternoon I started on the crankshaft. The shaft itself is 1144 stressproof, not that it needed to be but it's a little stronger and cuts quite well. The crank pin is W-1 drill rod. It was turned, polished, hardened and drawn out a little. It was then presssed and Loctited into the crank.
Every time I get parts made I want to see what they look like together so I pressed the bearings into the cases and took the slave rods off of the master. I inserted the crank and went to put the master onto the crank pin and discovered my first needed modification. The crank pin as designed is too long and won't allow the master to be installed. The master rod is .45 wide and the pin was .438 so I started grinding the pin down about .025 at a time. When I got to .305 the master rod would slip in. The hole in the crank pin is to drive the distributor and oil pump gears through another crank affair driven by the main crank. The original design is for a .125 drive pin but I don't see any reason why I couldn't just use a stub the same diameter as the main crank pin, that way there would be a little more support for the master rod although I suspect .305 would be more than adequate.
The first couple of pictures are of the rods assembled.
