- Jul 16, 2007
- 3,055
- 1,180
This morning I got started on the little right angle plate to hold the rockers for cutting the radius on the end. I put a .125 reamed hole in it and press fitted a 5-40 stud for holding the rockers. I also put a little boss on the valve end to keep the arm from possibly moving. I found a 10-24 tapped hole on my universal aluminum fixture block and mounted the angle plate. The first rocker got laid out with centerlines. Once the rotary table was indicated in I mounted the fixture block. In the second photo you will notice extra clamps mounted flush with the rotary table once I had the layout lines wiggled in and the clamps tightened I mounted the extra clamps against the sides of the fixture block. I have found that no matter how hard you try at setting up everything as perfectly as you can when you start cutting a radius it seems like that part is always shifted just a little. The extra clamps are used to adjust the fixture block. I make an initial cut and see if it looks like everything is even, if not I loosen one of the stop clamps, add what I think is the necessary shim, push the clamp back up against the fixture and tighten. I then take the shim out, loosen the fixture clamping bolts and push it against the now moved stop clamp and re-clamp. This way I can fine tune my cut so that the radius ends up perfectly centered on the square.
The first picture shows the angle plate mounted to the fixture plate. The second photo shows an overall view of the setup. The third picture shows a rocker arm mounted and ready to be cut. The fourth picture shows the radius spun on the rocker end. To get up against the body of the rocker arm with the cutter I slowly rotate the table and backing off until I see that I'm close. Once there I put a reference mark on the rotary table so that I can repeat for the other parts. It's better to stay a little away and file the piece rather than dig into the body and have an ugly looking gouge. I have so many hours in these things already I certainly don't want to start over with the whole process for just one or two arms.
gbritnell
gbritnell
