This is a commercially built compressor for airguns that will go up to 4500 PSI and costs about $500. The design is really simple and while I would caution you about infringing on patent rights, it wouldn't be difficult to build.
http://www.shoeboxcompressor.com/
Chuck
You are going to have a very difficult time obtaining 4500 psig with only three stages.
This type of compressor will have four or five stages. Each inter-stage must have a cooler, with moisture separator. Even air from a dry day will contain enough water vapor to hydro-lock the last stage of the compressor.
The hard part in designing a HPAC is keeping the cylinders properly lubricated without dieseling. If you think an engine knock is bad, you havent seen anything until an HPAC squeezes a bit of lubricating oil.
How many cubic feet per hour are you looking to obtain?
I worked with some 800 P.S.I. two stage ones used believe it or not for paper cutting (Gaskets actually). and they had a habit of dieselling even with some very special (and expensive) lubricant. I agree with you about the noise, terrific racket and very destructive could wreck the second stage in about 5 mins if left unchecked.
Regards Mark
Long ago I toured the Worthington Engine plant in Buffalo NY. They also made big air compressors. Walking about we came to a compressor shaped like a Pineapple, about 8-10 feet tall. 5 foot Diameter. We were told it was a 7K psi compressor off a submarine. One side was missing about 3 x 5 foot of casting, many inches thick in places, it seems that it hydro locked for some reason, Ouch!!
Cooling is always a big issue with compressors, the higher the psi the higher the heat rejection needed.
Hi Gus
Compressors are noisy things at the best of times but about a hundred of those all running together, cutting in and out, loading and unloading as the air demand varied must be Bedlam, It would shake the fillings out your teeth ! As for the heat they must throw out doesn't bear thinking about.
P1 * V1/T1 = P2 * V2/T2 familiar ?
Ya cannae beat the laws o' physics as Scotty from Star Trek would say
Regards Mark
Hi Entropy455
Super explanation, this is exactly the problem with HPACs it's the shock that does the damage, lubricating oil is even worse sometimes as has been pointed out, not only does it instantly vapourise at these T & Ps but spontaneously combusts leading to the "dieselling" effect
Regards Mark
