3D printed bevel gear
Here is the final result.
    135 KB
    144.3 KB
It is too much work to tear the saw down to actually try it but as near as I can tell it should work, or at least work when/if I print it using ABS.
The bore seems to be a little tight but it probably can be pressed on or at worse run a reamer through it.
Looks good ,I will be assembling mine shortly as well so I will let you know how it goes good work guys
