YOU ARE NOW ENTERING THE TWEAK ZONE
After reading and digesting the advise from Gail and Seagar.
I decided to make a new Contra Piston.
This time I used the David Owen method as recommended by George, (Serceflyer).
Let me tell you this is the absolute best way to make the contra piston, so without further ado here's my interpretation of the method.
A lump of spun cast iron for the new cp. The piston is turned down to 0.015" oversize.
End milling the cp to give a thin wall piston (1/32")
The cp ready for parting off
Brass for the cp mandrel.
The cp glued to the madrel with super glue.
After facing the cp, the compound slide is set over 1/2 deg.
The cp is now turned down with this slight taper, using the compound slide, until about 1/4 of its' length will enter the cylinder. At this point fine 440 grit emery lubricated with oil and a flat bar are used to further reduce the dia of the cp until about half of its' length will enter the cylinder.
BELIEVE IT OR NOT - THAT'S IT
NO LAPPING
The finished Contra Piston.
A little heat and a wooden clamp removed the piston from the mandrel.
The engine was re-assembled the new contra piston was tapped into place with a brass dolly.
Below is the result - the rev counter showed 7000rpm.
What's left ???, another turn of thread on the compression screw.
Best Regards
