This engine is the only horizontal twin tandem compound I have found online.
Looks like Corliss valves on the high pressure cylinders, and piston valves on the low pressure cylinders (am I seeing that correctly ?).
Normally a piston valve was used as steam pressures increased from 100 psi (+ -), to 250 psi and above.
Piston valves will withstand superheated steam, whereas D-valves don't do well with superheat.
Corliss was king until Charles Porter came along with the modern high speed steam engine.
Porter was heavily influenced by steam locomotives with high piston speeds, and so it was not a totally unique concept, but was unique to the stationary engine world.
The engine at this link has unsupported outboard crank pins, and so that puts the eccentrics inboard next to the flywheel.
The piston valves appear to be driven via rods directly from the eccentrics.
I can't follow the valvegear drive for the Corliss valves; photo not clear enough.
https://www.nmes.org/dee.html
Edit:
I have never seen twin piston valves either, but as I mentioned, I see a new type of steam engine about every day, and the variety seems to be endless.
