There will be no pumping action in the crankcase. A pump of some sort is used in multi-cylinder two strokes with a shared crankcase. This should help explain the concept. http://www.rcmplans.com/issues/requested/content/reviews/pdf/r-rv-berger-121997-1-1.pdf
hello
diesel pilot
Can you give an example of a positive displacement pump
Can you give an example of a radila flow compressor ...
sufficient to run 2 times speed compressor will ya?
What's your suggestion to me.
then waiting for the answer.
