mklotz
12L14 is a leaded steel that's an absolute dream to machine. I use a lot of it in my models.
However, it does have a well known tendency to rust much more easily than standard CRS or other common steels.
Recently, I've noticed mild surface rust developing on 12L14 parts on several models housed in a closed display cabinet in my office. I live in the semi-desert environment of Southern California so rust of any kind is unusual and rust inside an indoor cabinet is frankly astounding.
I noticed a correlation. The models showing rust were all placed in a part of the cabinet that is exposed to the morning sun. My guess is that the resulting warming of the metal makes it even more susceptible to the low humidity present in the air inside the cabinet.
The rust is only minor surface rust and, caught early, is easily removed with a bit of fine steel wool. A coat of LPS3 or Boeshield (my preference) should prevent more rust from forming on these parts.
Anyway, a heads-up for all you modelers. If you use 12L14, be careful about how you store models, especially if you don't run them often.
