Hello, here is the one I made in 2019, the casting is from Myers engine, 1/8 scale.
Not too difficulties to make it work, no substantial modifications, apart from some modification of machining dimensions to adapt to the foundry (not always very precise). I put 1 vitton seal at the bottom of the cylinder to avoid water leaks, a pump with a cylindrical piston and a gas heater, the most complicated was to manufacture and adjust the burner.
