Another notch on the workshop wall, this time a 1/5th scale model of a Denny Improved Ericsson hot air pumping engine. I drew it up from the original patent drawings and images of full size ones found on the net. The bre is 40mm and the flywheel 145mm dia. There is a mix of steel fabrications and parts cut from solid, no castings were used although I did cut the flywheel from a slice of 150mm dia cast iron bar.
There is a small camping gas stove's burner mounted at the bottom of the furnace which provides the heat source
It's knocking a bit as I removed the pump's piston so I could blow air into it for cooling therfore the rod is not being guided that smoothly but otherwise not running too badly.
